Hi all. I have a strange problem that I hope somebody may have heard of. my 02 caravan feels as if the trans is stuck in forward and reverse while running. while it is running you cannot even push it in neautral as it feels locked up, but when it is shut off it rolls fine in neautral. when at idle, if you put in forward or reverse you can feel it slip in gear but it will only move if you rev the snot out of it and then it jumps and stops. I'm in the proccess of getting a scanner to where the van is to check codes.
I recently had the trans go into limp mode & it ended up being solenoid # 3 in the pack, so the entire pack was replaced back in august. and thank you all for the info on this site.!
