While attempting to swap a tranny on our 02 neon, I noticed something diffrent between the tranny i took out and the tranny I was about to install.
The socket for the drive axle coming out of the tranny on the original has a 4 inch aluminum casing extension behind it that the replacement dosent have. We were aware the the 02 was a unique year and only an 02 tranny would work, but are there are 2 diffrent 02 trannys? Is this tranny that is diffrent from the original totally incompatible with my car, or can I just use a longer axle? I read that Dodge changed the tranny mid-year is this the diffrence? if so, is it the gear ratio or how many speeds it has? Which version did i pull out of my car? The replacement tranny I have has a tag
P04800269AB and no extension behind the axle socket, 3-speed or 4-speed? Teh tranny that i pulled had no tag but the housing # on the bottom is782Ad FF and above the axle socket on the housing is 782AD MM. Vin # is 1B3ES56C42D590649. Any help is greatly appreciated.
