1 - 3 of 3 Posts
This is a 03 Durango with low miles. 76000 a 5.9 4x4. Origianl ower and it has been taken care of. Had a trans flush at 50k
What I am experiancing is the trans is slow to engage into gear, if it sits more than a day.
If I shift it back and forth from R to D a few times it will work just fine and drive all day long without any issues. But if I start it up, put it into gear and give it gas, it wont move the vehicle.
I have herd that some of Dodges trans have issue and I had herd they can be an easy fix without a rebuild.
Anyone have any info or experiance with this?
DO NOT FEED THE TROLLS!
This is common and is not terribly detrimental.
Try starting it, shifting into drive, holding the brake while applying a bit of go-pedal for a few seconds. It should perk up immediately.
Or, put it into neutral for fifteen seconds or so.
Basically some kind of anti-drain-back valve isn't holding as well as it should.
You may want to do a fluid AND filter change. This will allow you to inspect the pan, magnet and filter for debris. ATF+4 fluid is recommended.
The only drawback about a transmission flush is that it won't address a restricted filter or debris in the pan bottom. Debris can also plug up an ATF cooler which will be the beginning of the end.
1 - 3 of 3 Posts
