By 'nothing there', you mean that the pedal is soft and low? I would start with a 4 wheel brake inspection (rear drum?). Look for loose or worn hardware.
Is the master cylinder fluid level still OK? Master cylinder issues can be intermittent. I would think that a booster issue would be more consistent.
You can downshift to 3 or L if you need engine braking downhill.
