1 - 2 of 2 Posts
· Registered
I have a 2006 Daytona Charger with 33K miles. In the last 2 months every time I fill up my fuel tank for the next 20 miles or so the car will stall at stops and will cut out when accelerating. After the 20 miles or so goes back to normal driving conditions until it is time to fuel up again. Dealer put on computer and there are no codes showing...Next time I need fuel I plan to only fill tank 1/2 way to see if that make any difference but it is frustrating not knowing what to do to fix. If anyone has any ideas I would appreciate hearing them...thanks
· Super Moderator
It sounds like the ORVR (on-board fuel vapor recovery) or EVAP (evaporative) emissions systems are malfunctioning. There should be a vacuum hose routing map under the hood to try and trace the flow from the filler tube and fuel tank vents through the canister to the purge solenoid and to the intake manifold.
Liquid fuel may have entered the charcoal canister and flooded it. This will cause a rich mixture condition when purge is occurring.
It may not set a fault code and you may want a service manual for diagnosing this.
1 - 2 of 2 Posts
