07 Kia Sportage 4WD- 95,000 miles. This car has had this problem since we got it 4 years ago with 36,000 miles. Problem is it was not that noticeable. The front end(I think)has a low speed wobble that you can feel in the steering wheel. Once you hit 30mph it disappears. The only thing the car has done that tells me there is a larger problem is I pulled out of a carwash and did a hard right turn(low speed) and the steering wheel wobbled really bad then it just stopped. Since then it's just got the very slight wobble.
That is the only real noticeable thing that it has done. I just got done rotating the tires,made sure a wheel weight had not fallen off,air pressure was good,the tires as far as I can tell do not have a steel belt slipping,inside of the rims are clean. Rotating the tires did not help. What do you think is the problem? Could it be something as simple as a tire is out of balance and it does not matter if the tire is on the front or rear of the car? Bad ball joint? Struts were replaced last year. Thanks for your help!
