Solenoids are rated by the amount of push or pull that they can create. Just for giggles, see if you can determine how much effort it takes to actuate the load being driven by the solenoid. A gun trigger pull scale might do the test. The length of solenoid shaft movement is very important, too. Solenoids will have many shaft travel specs. Check into what you need in both respects.
