I believe MAC tools has the puller to do it. There is a topic with a picture of the puller, which is like a tripod with three places for lug bolts/nuts to be attached to the base and then a bolt and a hammerhead piece that attaches to the end of a bolt that will be tightened against the axle end. You use a sledge hammer to tighten the drum puller, then you use a wheel puller to pull the axle from the housing.
