1965 dart door strikers
2986 Views 8 Replies 4 Participants Last post by  chuzz
Can anyone tell me how to adjust my doors on my 1965 dodge dart. I just have everything aligned and when i put in my new door gaskets in, the door wont close. I have adjusted my striker about 100 times and no luck. Any help would be greatly appriciated.
1 - 9 of 9 Posts
· Registered
Have you checked your hinges for loose bolts or perhaps cracks? Maybe instead of the striker, you should try adjusting the catch mechanism in the door. Stupid question though, were they closing properly before you installed the door gaskets? If so, you need to go back over the gaskets and make sure they're fitted properly or maybe the wrong thickness?
· Registered
Discussion Starter · #3 ·
Yes, the doors fit perfect prior to installing the door seals. I didnt think you could adjust the catch in the door. I didnt see any adjustment there. Looks like it is stationary. I will look again. Thank you for your reply. I had a time with my 65 belvedere as well. Those type catch assemblies are wooping me
· KOG
Latch in door cannot be adjusted. If the door closed properly before your only option is to force it closed until the new gasket begins to fit the door frame.
· Premium Member
If the door is aligned properly and the lines outside match up, you are right, the door mechanism itself does not adjust, the three or four screws are recessed into the door edge so they won't move. Get inside the car back seat with the driver seat laid forward and see if you can see where the door is hitting the striker plate, high or low, then adjust from there. If it is hitting against the outermost part of the striker plate, remove the gasket and see if it clears then, might have to make a thinner gasket. Basically, without knowing where it is touching, adjustments are a guessing game.
· Registered
It sounds plain and simple to me that the gaskets are the problem. Did you purchase them from a reputable Mopar repro place or some aftermarket place like J.C. Whitney? If aftermarket, then it may take a while to get them to crush in and they may never fit correctly.
· Premium Member
I think you may be actually talking about the door seal all the way around the door itself, which was my misreading. Pretty much the same thing applies, figure out where it is tight. Sometimes it is the end piece or the rubber just isn't compressing enough, but either way, figure out where the tight spot is first, it may be kinked from shipping/packing and is crushed the wrong direction in a spot. If they overall just aren't compressing enough to allow the door to close, send them back and get a refund. There are enough companies out there which do make proper fitting ones. Did they install correctly without any modifications needed?
· Registered
If you have the time, you may just stand there and open and close each door several hundred times. But that could be very tedious, boring and tiring. Just keep the doors closed for few days if you can and the new gaskets will eventually "crush" into position.
1 - 9 of 9 Posts
