Just a couple questions. After we had put the timing chain back on we had some issues getting it running good, but running to say the least. We took the car to a transmission guy and had it rebuilt with a shift kit put in. We removed the stock intake and carb and replace with an Edelbrock performer intake with a 600cfm electronic choke Edelbrock carb.
I have a question about timing on this car. The motor is out of a 71 model, stamping shows its a 71 model 318. But what I dont understand is the stock timing tab that is apart of the timing cover. It only goes to +10* to -10*.
I have done some research and see where guys have there cars timed at 8* BTDC and some beyond 10* BTDC.
How do you figure the timing beyond 10*??
Are they using a special timing light??
The reason I ask the questions above is b/c when you give it a quick jab of the throttle it back fires through the carb. I have it set on TDC of the compression stroke. IS THIS CORRECT???
Is the timing still set RETARD??
And what should be the vacume advance timing be so when I set the initial timing its not knocking when under heavy pedal??
How do I check to see if the points are still good??
