1 - 11 of 11 Posts
I recently purchased a one owner car from a ranch in Montana. I'm going blind trying to find rear quarters for the wagon. Also looking to upgrade to disc brakes in front, but have the little 13" stock wheels. Any advice out there? Thanks!
2002 Ram 2500 Quad Cab 4x4 with Cummins. 2021 Jeep Grand Cherokee L Altitude
There were disc brakes available on later A bodies with the 5x4in bolt pattern. My 72 Demon I owned had them. You really need to upgrade to the larger bolt pattern and with that comes all sorts of wheel options then. I know it can be done, someone on here has probably done just that. The quarter panels were known to rust out. I had a 63 wagon with the same issue and we formed new panels, but I'm sure a good steel fab shop could make much better ones then we had. Enjoy your wagon.
Welcome to Allpar. You might have to find an old-school body tech that can 'make' patch panels for the rear quarters. The Valiant and Barracuda body panels I see for sale online are for 2dr and maybe 4dr cars. The wagons may be different. Join a club like WPC for resources and fellowship?
Some front disc conversion kits are out there. Jegs recommends a minimum 15" wheel, so you might have to find a matching bolt diameter with low-profile tires.
Right Stuff MDC66SD: Front Disc Brake Conversion 1960-76 Mopar A-Body (Barracuda/Dart/Duster/Valiant) | JEGS (at https://www.jegs.com/i/Right-Stuff/965/MDC66SD/10002/-1 )
Complete Dodge Dart Mopar A Body Disc Brake Conversion Kit for 5x4.5 Wheels | eBay (at https://www.ebay.com/itm/Complete-Dodge-Dart-Mopar-A-Body-Disc-Brake-Conversion-Kit-for-5x4-5-Wheels-/172196593833#vi-ilComp )
All said and done, the complete conversion done correctly could go over $1000.
Wagons should have 10" drum brakes already. If the original brakes are kept in good working order, they should be safe for normal driving.
Discussion Starter · #4 ·
Thanks so much! Pretty new at this...
I've purchased two: one from Classic Industries [recently] and the other from Laysons [ years and years ago].
2 door hardtop 63 though, but worth investigating Classic Industries.
You will also need the master cylinder, combination valve and associated steel brake lines to go with it. The PJ kit just shows the front brake hardware. It is incomplete without the disc/drum hydraulics.
Reactions: saltydog
They do have other kits that have everything, I should have put that link.
Reactions: ImperialCrown
1 - 11 of 11 Posts
