Welcome to the forum. Yes, the quarters are the same until you get to the top where the convertible top cuts in, but below it is the same. You most likely will find braces and brackets/support around the convertible top itself, which will be heavier duty in the convertible. As far as other parts go, yes, except for the convertible specific parts, should be able to swap without a problem, interior door panels will be different, rear seat is different, but most of the hard parts are the same.
