Could be lots of things.
1) Vacuum leak.
2) Incorrect point gap.
3) Incorrect ignition timing.
4) Lean idle mixture at carb.
5) Incorrect idle setting.
Best to do a full tuneup, making sure everything is to spec, including idle mixture, fast and slow idles, choke adjustment, proper function of heat riser valve, no vacuum leaks.
1) Vacuum leak.
