1975 dodge dart se 318
the black w/t yellow tracer coming out of the ignition module has only 1.0v where as all the other inputs have the correct voltage.
when the key is turned to the start position the voltage gauge drops down but the starter never engages.(trans-linkage is not hooked up yet but the trans is in park and all wiring to trans is connected and in tact. (also was a problem before removal of the motor
