If only 3 wires are showing spark, it sounds like the wires are bad. I would replace all the wires and the plugs if they have not been done within the last 30,000 miles.
Living overseas does put a different light on things; especially that the 1970's Electronic Lean Burn systems basically 'sucked' whereas the newer ones are tolerable. Unless the owner was 'obsessed' at keeping the car 100% original, I to would convert to the vacuum advance style ignition. For that matter: the early ELB's were so bad that even our EPA turned a blind eye towards such ignition conversions.dopus said:I cheked the gap and it looked ok. The owner have decided that she will get a electronic iginiton kit ( like the mopar/jegs/summit/proform kit wht distributor, computer. resistor and wiring harness) and new spark plug wires It is on its way from Summit., delivery takes about around 7 days ( I live in scandinavia, Europe), So next weekend we will try to wake up the 360 with the new ignition kit and plug wires.
One question, with this new kit, can i stil use the mopar coil in the car or do I have to get a new one?
