1979 Dodge Power Wagon 150 electric fuel pump upgrade.
4647 Views 5 Replies 5 Participants Last post by  Davis Wallick
Where would be the ideal place on the truck to install a external Mr. Gasket electric fuel pump?
1 - 6 of 6 Posts
· Super Moderator
Welcome to Allpar. Do the instructions offer any good ideas?
I would think that mounted on the frame by the tank would be best as long as it is protected from the elements. A splash or dust shield could help.
The firewall may be more free of dust and splash, but I would be concerned with the high underhood temperatures.
· KOG
And bypass the mechanical pump, do not pump through it. If you pump through it and its diaphram leaks you'll fill the crankcase with gas and there goes the engine. Fuse the line to the pump.
· Premium Member
Good one KOG, and also, when you mount it, place a piece of rubber between the mounting bracket and the frame to reduce the HUMMMMMMMM.
1 - 6 of 6 Posts
