Hi! New member, and looking for advice.
I already searched whatever I could on the subject and haven’t found much of anything to assist.
I am rebuilding my truck and have done a fair amount already. Starts, runs, all good. Ran into trouble with my lights, running lights, and signals.
I did swap out all my sockets with wedge types, rear end is working perfect. Front end not so much.
I picked up and installed a headlight wiring kit that pulls from the battery vs through the wiring. Doing this allowed me to redo all my wiring, trimmed out extra wiring for the headlight from factory wiring, as my kit simply bypasses it all but uses the drivers side as a signal for the relays.
What’s happening tho is I swapped all the factory bulbs with LEDs, and I finally found a flasher that actually works with it, however it works properly only when the lights are off. As soon as I turn my running lights on and hit the signal my tail lights work as it’s supposed to, but the front, my turn signals stay lit, and my marker lights flash.
As far as I am aware, my rewiring is good, I have strong ground wires, I can’t say I know how to use a multimeter, but it’s on m todo list! I have no resistors installed. My hazards work as intended(I know it’s a different circuit). My components on the column is new, new headlight switch. My new headlights have an LED DRL halo I have tied into the marker lights, but that shouldn’t draw anything that conflicts.
If there’s anything more, I’m happy to answer, and thanks for taking the time to read the story!
