Hi all heres the dealio...I bought this daytona 2mos ago it had sat for 5 yrs or so in a field by my house. The car has 54000 original miles ,got it from original owner,brought it home and it was getting no fuel,I dropped the fuel tank and replaced the pump and filters ,lines and put fresh fuel back in it ...it started right up on the second try and has been running fine ....flash forward I parked it for 1 month until I could do some more work to it,now it will start but lopes and wont come up to idle and dies ?????? The code key dance comes up 12 and 55 no trouble there when i spray throttle body cleaner in it it will run and sounds fine no misses or anything ,this one has the multi-point setup for the 2.2 liter Turbo motor ,where do I need to start lookin into for the cause ...fuel injectors ??? sensors ???? Its got fresh plugs ,coil wires etc. The electronic stuff is where I am lost the vacuum hoses all seem to be connected ????? I am losing hope on it ,any advise would be appreciated ,the car is in good shape and I need a gas mileage car ,however I am thinkin of the worse scenario ,if i cant use it I will sell it ,text[at]3606088518
