If there is no bare steel showing where theresistor attaches, then there can be no current flow. If there is still good steel under the corrosion, clean it off and attach the reisitor again to see if it works. Have you measured the resistance value? It should be in a very low value around 0.5 to 5 ohms. If it is open, try Radio Shack or an electric motor house for a replacement.
