‘90 Chrysler Imperial Brake Issue:
After replacing the fluid level sensor, the Low Brake Fluid warning went off and so did the ABS light.
Current issues:
-After starting, when you put your foot on the brake to shift into any gear, the ABS light comes on and quickly goes off.
-When you hit the brake quick or somewhat hard, the ABS light comes on for a second AND the brake pedal gives, as if the ABS is engaging. The actual red brake light never comes on.
-I am pretty sure brake fluid is leaking into the car, see pictures. Is this happening because of too much fluid?
-When stopped at a light, there is an occasional pulse in the brake pedal.
Any guidance is appreciated! Perhaps I need to have the entire system replaced. Any recommendations of where to do this in South FL?
Current issues:
