The electrical problem should be checked out for alternator/battery terminal/wiring problems. Fluctuating voltage certainly does not do any favors to the control modules.
Any PCM/TCM fault codes? The later TCM software had improvements to reduce sensitivity to intermittent electrical issues.
An ambient/battery or ATF temp sensor may be acting up.
