Hi, my name is Kevin and I'm trip'n. 1990 Plymouth voyager 3.3 V6, 100 K miles. Symptomology; The engine starts and idles perfectly well but giving it gas just above idle under load it bogs, symptoms get worse as it warms up to the point you have to almost drive the car at idle because it will accept no pedal. I checked fuel pressure at idle at 65 lbs at the shrader, so I replaced the map sensor, TPS, the entire ECM, and the cat. I stripped the wiring harness from the ecm looking for bad grounds or bare touching wires and found nothing. Still doing the exact same thing. My next best guess is fuel pump or filter but after having done all the work I have already done with no results I am afraid to drop the tank and spend the money just to have it not fix it again. I bought the vehicle in this condition thinking I would just read the codes and fix it without a problem, so I got it cheap, but now I have already spent more money on parts than I payed for the car. I am hoping someone here can tell me what is going on with this thing, if I need to drop the tank so be it but I have a suspicion it's still electrical. HEEEEEEEEEEELP!!!!!
Please email me if you have a solution to my madness
[email protected]
Thank You Very Much!!!
[email protected]
