Welcome to Allpar. If you have lost Park and the vehicle rolls, then the problem would have to be somewhere in the transfer gear, transfer shaft, differential or axles area. It sounds mechanical and not anything electrical or hydraulic. If you still have Reverse, then something must still be connected?
Can you pull the differential cover for a look? You have the A-604 (41TE) transaxle.
http://www.shinseiauto.com/japanese/transtar/42rle.pdf
