Hi folks,
I recently picked up a 1992 Dodge Shadow with the 2.2L to fix up and sell.
When I got it the left turn signal worked fine, but the right side stays solid and the hazards didn't work. I pulled the hazard relay and reinserted it. Now, the hazards work and the indicators come on however the right turn signal still doesn't flash with or without the hazards. I changed the side marker bulbs on both rear sides and swapped main bulbs in case that was the problem, but alas nothing. Intermittently the right signal will start working but most of the time no dice. Fuses are also all good. I should also note that when the hazards are off and you activate the right side, both front and rear come on and stay on solid including the indicator. However when the hazards are on, the front right side flashes but the right rear does nothing at all, not even solid.
Any ideas of what to test to nail this? This is pretty much the last issue I need to fix to have it safety inspected for the road.
Regards,
Cody
Regards,
Cody
