Even though I bought the extra wheel/tire combo I went ahead with my idea for the axle cart because this will take up less space in my crowded garage and will make it easier to get the axle under the van when the time comes. The casters are spaced to support the axle tubes just inboard of the spring pads and will let me "roll" the axle on the cart to drain and fill and change the cover gasket.
Pic below shows how it will look in use. Ignore the upside-down-ness and pretend the trailer is not there. I already had to shorten the base board to clear the brake drums. I'll need to jack the thing up in the garage and put jackstands under the brake drums so I can remove the cart to get the other axle out of the van so I can put this axle back on the cart to take to the van..
Finally found the BOM on the long axle tube.
