My 1995 Dakota has run almost trouble free... but recently has gotten a weird problem.
The truck has about 180k miles on it and deferred maintenance (insert face-palm graphic here) had caught up with it: driveability problems (rough idle, stalling, the usual stuff) plus "throwing" a trouble code. That code led me to the EGR valve. Replacing that helped a lot and haven't had the check-engine light come on since. New wires and plugs (replaced the platinum with OEM-spec Champs, per advice here on Allpar.) Spray cleaned the throttle body (gunk city but not as bad as the old EGR). So all this has helped, except...
If the engine is warm, and I shut it off for a few minutes (like when filling the gas tank, for example), the engine will crank strongly but won't fire up. How have I been getting it to start again? Nothing...for two-plus hours, when it'll start like nothing had happened before. (The engine will typically restart only if I try right after shutting it off when warm, or always when cold.) No problems when the temperature gauge reads below the normal range, except when I have to wait until it's stone-cold because I shut it off when warm.
Until I did a lot of testing until I could re-create the problem, it was as if there were a Murphy's Law sensor under the hood that could detect, for example, being in a supermarket parking lot on a 95-degree day with newly bought frozen food in the cab. I have since discovered that I can run nonstop round trips, for example, driving to a post-office drop box and back. Not very practical.
I should mention that the trouble occurred after the water pump failed and the engine overheated. The water pump has been replaced and no more problems with overheating/staying cold.
[Speaking of codes, whoever wrote this computer software isn't a car guy, because the spell-check doesn't recognize "driveability."]
