The BCM controls the low washer lamp, so unplugging the low washer switch on the reservior should turn out the warning light.
The switch is located towards the bottom of the reservior, so you may have to empty out the reservior and remove the battery, battery tray and reservior. Empty the washer fluid into a clean container before servicing it. If the fluid is comtaminated in any way or has any debris in it dispose of the fluid, wash the inside of the reservior out and use fresh washer fluid.
Many times the low-fluid (encapsulated reed) switch gets coated with 'slime' and sticks. Sometimes they can be cleaned, but it may also need replacement.
