Hi all, I own a 1995 Lebaron and recently im having some weird problems with it.75% of the time when I start the car I don't hae power mirrors or radio power? Then ill tap on the fuse panel and cycle the key and it starts working again.I'e pulled the two 30amp breaker fuses in the fuse panel and replaced them even though they aren't related to the two devices not working because the were loose in the tabs.Not sure if there was a purpose to that but regarless.I checked the radio harness and the power thats missing to make it work occasionally is the 12olt battery power,not the acc power weird huh?? Im lost ,if the a fuse panel problem or relay problem and if so which one?? Im also looking for a power window switch and hub cap ,the 4 window controller switch drier side and the gold accent hub cap blew off when I hit a hole.Thanks a million for any guidance!!!
