I have a 1996 Jeep Cherokee. Manual transmission. When shifting, idle speed hangs up [idle high] and this causes drivability problems. Esp. when going from a stop light into first gear. Have replaced IAC motor, TPS and have checked all vacuum connections.
Also have checked engine ground wire. Problem seems to be intermittent but happens too much.
Any ideas out there on what I should check. Thanks.
Ramvan 1986
Ramvan 1986
