I am trying to replace the basic gauge cluster in a 1997 Caravan with the premium cluster, the one with the tachometer. I picked one up from the yard (yes it was from a 1997). Everything worked, except for the transmission gear indicator. After looking at the Mitchells manuals and AllData, it appears that the transmission gear data is passed from the TCM, to the gauge cluster, via the CCD data bus. The origional, base cluster had the mechanical gear indicator.
Here are my questions:
Did Chrysler make a premium cluster with a mechanical gear indicator?
Is it just an issue with the TCM not being set to send the gear posisition data to the cluster?
Here are the vehicles specs:
1997 Caravan
2.4l, 16 valve, 4 Cylinder
A413 / 31TH transmission
Thank you for your input.
1997 Caravan
