Afternoon Folks:
My 1997 Plymouth Grand Caravan 3.8L got a stuck caliper and ruined the pad
..so I changed both front axel's brake pads, calipers, and roters. In the process, I (obviously) had to add new brake fluid and bleed the front two brake lines.
Following the repairs my ABS or Brake Light now stays ON when the engine is running. I made sure that the brake fluid was up to the full mark and performed multiple "turn on, turn off" key sequences in an attempt to have the light go off. When that did not furn off the ABS light, I went to my local car parts shop and used their generic "Code Reader" to "Clear All Codes."
Still the light remains on. :angry2:
So now I have a couple of questions:
Is it possible the generic "Code Reader" did not read and/or reset my ABS light due to the fact that the "Code Reader" is such a low end device? NOTE: When I asked the "Code Reader" to pull all codes, it did not show any entries for the ABS system at all.
If I can get my hands on a higher end "Code Reader" which will allow me to read the ABS codes, will it tell me with any specifity why the light is on?
Lastly, having never dealt with a modern ABS equipped vehicle, I have no idea if: the ABS code stays on until it is cleared by a "Code Reader;" or turns itself of once the error/problem condition corrects itself.
Any ideas on what and/or how to repair the vehicle so that ABS light goes off?
Any information you can provide will be greatly appreciated!
Poor Paul
Poor Paul
