I bought this truck with a cheap aftermarket stereo installed and direct wiring ran from the deck to the to the speakers. I put in a factory deck and reconnected the factory wiring to the speakers but it kept blowing fuses. Finally I narrowed the issue to the Infinity amp. I had an amp from a Durango and put it in.
The question is: should I eventually get a Dakota amp for better sound? They are different part numbers, I assume the factory wouldn't have used different amps unless something was changed. I'm a novice when it comes to audio.
