Troubleshooting is a process of elimination. The reason I asked you to do the check, was because I had a hunch that the cluster might be the problem, and wanted to work back from there. As an experienced technician, I have learned to look for the simplest possible problems first. We don't need to go after the powertain stuff until we have eliminated the cluster issue. That being said, I'm still not sure weather your cluster is bad or not. Exactly what happened when you did the cluster test? When you say "all the lights light up", what lights are you referring to? The lights in the cluster, or others? This is important.
Right now I'm thinking you possibly have a power to cluster issue, bad cluster or body control module/computer issue. This can be caused by bad wires, or a bad unit. You are going to have to eliminate each one, one at a time. I'm seriously worried about the body control computer at this point, as it is interconnected with all the other computers. If it's bad, it can cause a variety of issues. But, like I said, we should eliminate the cluster first.
Here is the order in which you should be checking things: Make sure power is getting to the cluster. If not, find out why. If so, is the cluster behaving correctly? If not, it could be a bad cluster, bad BCM or the wiring in between. This is where things get complicated. You will have to verify that the BCM is getting power, as well as the BCM is communicating with the cluster. The only way to do this is to break out the multimeter, and dig into the dash. You have to get access to the connectors at both ends. Ohm out each wire (WITH THE CAR BATTERY DISCONNECTED!).
Looking back at my message, I am starting to think that this may be too difficult to figure out via this forum. Plus, you are at a serious disadvantage without the service manual. If I were you, I would seriously consider getting a friend with some experience in electronics to help you, and get a copy of the factory service manual. It has all the schematics and diagrams needed to properly troubleshoot this problem.
FYI, the body conrol module is connected to almost every other computer in the car. It communicates with: the airbag controller, the instrument cluster, the transmission control module, the sentry key system (if you have it), the powertrain control module, the ABS controller, the power distributuion center, the windshield wiper system, lamps, speed controller, HVAC system, keyless entry, fuel sensors, door locks, power windows and other sensors and modules. There are at least five multi-pin connectors attached to it, with about 58 individual connections going in and out of it. Bet you didn't think it was that important, did you? That's what I mean about complicated, and I havent even started talking about the other computers yet. Still feel up to it?
