I am trying to get a Troy-Bilt 2 cycle gasoline trimmer to run. Unit is only several years old and was running earlier in the year but stopped. Pull repeatedly on starting cord but no start. Gasoline is correct mix of 50:1 fuel to oil. I removed the spark plug and it was fairly clean but decided to clean and gap. I hold the spark plug connected to its cable against the head and pull starter cord rigorously. Consistent spark jumps the plug gap so I know that the ignition module is functioning.
I opened the housing with the air filer and sprayed starting fluid into the carburetor opening. Repeated pulls on the starter cord and spinning the engine but still no start. I am stumped. Any engine that gets spark and has starting fluid sprayed into the intake should start and run a few seconds. Two cycle engines are pretty simple so I am befuddled as to the next step.
Picture below of carburetor in link. Could I have a flooding condition with the carburetor and the overly rich fuel mixture along with starting fluid is causing the no start?
Dropbox - Gasoline Trimmer (at https://www.dropbox.com/sh/j24mgzy8bv85zsr/AAC8LRtkQ6tNFxAVJaxPqjoca?dl=0 )
