Hoping maybe someone can help. Here goes
First problem was with stalling at random times. Fuel pump stopped working one day and filter was plugged solid. Changed
About 2 weeks later started misfiring, checked coil. Sparking only on 4 cylinders. Changed
Kept stalling at random times again. Checked fuel pressure (Constant 48 psi) Changed idle motor.
Drove 2 weeks this time started hesitating and popping at random times (p0106) Checked plugs/wires and replaced
Made it 2 days, same thing. (p0106) MAP sensor changed
Went 8 hours before doing it yet again except p0401 EGR. Clear codes, runs fine. Tried to reproduce it, drove around for over an hour but couldnt. Drove 2 blocks to the store and it did it. Very random
I took a peek at the crank sensor wires just to see if they had a break rigth there at the sensor like most develop, but no luck.
In all the years working on these things i have never encountered this before
Only thing not checked was TPS
Any input would be much appreciated
