Check for powers and grounds at the PCM. The Rd/Wt wire should have 12 volts battery power. The Wt/Bk wire should have 12 volts with the ign on. Both Bk/Tn's need to be a good ground. With these in place, the scan tool should be able to communicate with the PCM.
The Dk.Gn/Or wire from the ASD relay is powered by fuse #3 in the underhood (PDC) fuse/relay box. It also powers the PCM and ign coil. It has power for a couple of seconds after theign is turned on and turns back off if the PCM doesn't detect engine rotation through the crank position sensor.
If the 5 volt (Vt/Wt) or 8 volt (Or) sensor wire outputs from the PCM are shorted to ground, the PCM will go into protection and not communicate either.
