Seems like when the minivan gets hot then it has issues starting. If I get it started then it grovels or runs rough and I can't get it to rev up. If it does get going down the road it may stall. Getting engine light on when going from 7000' down to sea level or close to sea level. I have a scanner but my mechanic says that those cheap scanners can screw things up. He has a more exensive scanner that works well. We were getting codes for misfires.
So we have checked the wire harness and it looks good. Changed out the squeaky serpentine belt. Checked the cam sensor and cleaned it. Put in a new heat sensor. Put in a new fuel filter with the fuel filter lines on it. This fuel filter new has three lines coming off of it and you have to lower the gas tank to install the thing. I was getting some black stuff out of the old filter.
So gonna drive it to see if it does it any more. Any ideas on why this minivan is doing this? It only has 73,000 miles on it.
