During the winter time I noticed that the discharge hose from the air conditioning compressor to the condenser had an oily area at the crimped fitting (hose to pipe). Since it was winter and I was not using the air conditioning system I postponed any attention to the matter. Now spring time is here and I revisited the leaky hose. I replaced the hose and then proceeded to evacuate the system and get ready to charge refrigerant. Unfortunately I found that the system would not hold a vacuum. So a leak somewhere else. After more investigation and using a leak detector I find that the front evaporator has a small leak. Being 22 years old I guess one should expect that.
Removing the instrument panel to gain access to the HVAC plenum box and evaporator is a tedious chore. I have done this repair before but not sure I am up to this task again. Does anyone know what the book repair time would be to replace this front evaporator on the 2000 minivan? This will be expensive because of labor time and then the cost of a replacement evaporator. And probably should replace the heater core while access is open.
