Have a 2000 dodge neon. Girlfriend bumped a pole. A few weeks later check engine light came on. Then a week later her call stalled out and would not crank. After we towed it home I tried looking under the hood. The battery was taken and tested and they said the battery was bad. Replaced it. The PCM was erased when the battery died so we can't check the code. I can jump the starter at the PDC and it will crank the engine. Replaced the cam sensor and re spliced the wires at the nuetral safety switch. Nuetral safety tested out fine. Starter is fine and all the relays tested out fine when I checked them
All. Problem is when I turn the key, the dash lights up and gauges all work. When I turn to start, nothing. Radio shuts off while I start like it should but the started doesn't even kick in. The relays won't click or anything. The starter signal isn't getting power I turn to start. I started checking the PCM connectors and pin 20 has no power. Any ideas would be greatly appreciated.
