2001 pt asd will not reset . no codes 'no bad fuses,will start and run if i bypass asd.correct key any help is appreciated.thanks if you try to start motor cranks ok no spark or fuel no warning lights ever thing seems to be normal .there is anti theft it reset when set off.this is a new condition .moved car in driveway ever thing ok next day would not start. the fuel pump runs when you turn key on or sounds like feul pump.have swaped out relay for a good one.has a skim key
