Best start with some background. My 01 PT, non-turbo, 5spd is won't start. I started having issues about a month ago, when it left me stranded about 15 miles from home. Trailered it home, replaced the camshaft position sensor and the crankshaft position sensor, and fixed the frayed wire to the Crank sensor. All was good for a week or two, until I headed to Kansas City (about a 5 hour trip). It started acting sluggish, no power up hills, and got worse as I went along. Finally got to where I couldn't do more than 45 up a hill. Trailered it home again. Found the EGR actuator to be causing a vacuum leak, so I took the actuator out and blocked off the egr pipe with a piece of soda can, (disabled the egr) just to see if that would help before I spent the money on a new actuator. Car started fine, backed onto the road, and died, and hasn't started since. It cranks strong, timing belt is good (the camshaft turns, anyway), but I have no spark. Not even a little. The only codes in the computer are abs codes.
Anyone know what I should look for as far as the no-start issue goes? I guess I'll have to address the original problem eventually as well, but you know, one thing at a time!
It's got me baffled, because it was running fine when I backed it out, and it just quit. No coughing, no chugging, just shut off.
Any insight would be greatly appreciated.
