The clip-on braided ground straps are more for static electricity grounds than an actual electrical ground. The true pump/sender ground is an eyelet terminal and black/* wire screwed elsewhere into the body.
There should be a schraeder valve fitting on the fuel rail to measure or release fuel pressure. Discharge the fitting into a rag to reduce splash.
It might help you with the details of the repair to get your hands on a service manual.
