Welcome to Allpar. P0445 is an evaporative emissions fault code, like a leaking gas cap, cracked fuel vapor hose etc. It won't affect the car's starting or not starting.
Check for spark, fuel and compression while cranking. The spark plugs could tell a story as to why (carbon fouled, wet with gas, etc).
Some sensors may not throw a fault code and still be the problem (crank position sensor, etc). Diagnose before replacing parts.
