I would suspect the rotary valve in the rack and pinion assembly has developed hardened seals due to age At cold start up the seals do not flex as the steering input shaft is turned to direct hydraulic fluid properly to the internal piston to assist with steering effort. So in effect you have very hard or difficult steering due to lack of assist. After running a few minutes the seals start to flex and seal internally and then direct fluid properly and steering assist returns. In other words your minivan has "constipated steering".. . . .When this 2002 caravan sits for days than starts up,when cold, sometimes the PS is late to engage for 1 to 2 minutes at most. PS Level is ok. Also... The pump does not sound until a minute or two when this happens. Otherwise its fine. . . . .
The pump is not the problem because after warm up if the pump were losing pressure steering assist would be lacking. But you indicate that after a few minutes at start up steering is fine. If there was debris in the system causing blockage steering assist would be lacking even after warm up.
You have proper fluid level. Adding fluid will NOT resolve this issue. See attached image.. . . .Should I add ATF+4 TO SLIGHTLY ABOVE the full line. Does the resevoir need service. No leaks present! . . .
