Put a new Timken wheel bearing/hub on the right front and put new brakes pads on the front. Everything looked and seemed normal and torqued to spec. Car has 187000 miles.
Now I am getting some rubber rubbing sounds when turning at low speeds and quite a bit of steering wheel shake when braking a high speeds (50 MPH and up). It does NOT pull or wander or make any noises.
I had neither issues before i put the new parts on.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
