H
got a 2002 pt cruiser thurs it starting acting like running outta gas so got stopped side road and cad converter on fire put it out before caused any damage at all. luck there. anyway cut it off ran a straight pipe in its place still acting crazy so ran pressure ck and it is got good pressure to fuel pump when motor hot or cold. did a ck it said cam poss sensor bad I put a new one on it. still same then I cleared computer out read top o2 sensor so I replaced it and now says needs a crankshaft sensor. any ideas at all .bec ause I think the sensor is fine think its just goin to read something different every time and not fix issue. can let it set and idea . sets and runs fine but when put in gear and try to drive it after it heats up again it acts like starving for gas and only way to keep running is to fan the gas pedal . any ideas at all
