Welcome to Allpar. P0700 is just a PCM (powertrain control module) code telling you that a code is stored in the TCM (transaxle control module). It has no real diagnostic value. You need the fault code stored in the TCM for diagnosis.
You may get the needed code in the instrument cluster self test (see video) if it appears in the odometer display, otherwise you will have to find someone with a more specialized scan tool that can read Chrysler TCMs.
http://youtu.be/2mtmyl5VDFY
