I've had the almost exact same experience as this thread:
07Sebring codes 700/765 looking for shop in Albany, NY area (at https://www.allpar.com/forums/threads/07sebring-codes-700-765-looking-for-shop-in-albany-ny-area.217841/ )
Didn't want to muddy that thread, so starting new one specific to my situation...
121,000 mi, transmission shifts nice and smooth, no slipping. New fluid/filter/flush 1 yr/5,000 miles ago (ATF+4), no leaks, proper level. PCM replaced with rebuilt unit 2 yrs.10,000 miles ago. TCM swapped with used unit 1 yr ago.
Got p0755, 2-4 solenoid circuit (only, no other codes)+limp mode. Like the thread above, seems random, sometimes 300 miles between codes, sometimes 5 miles.
Here's what I've done (still have the problem):
New Mopar Solenoid pack
New Mopar In/Out Speed Sensors
Thoroughly cleaned battery and body/trans ground connections
Swapped with old/original TCM
I suspect wiring or PCM.
Can anyone help with wiring diagrams or testing procedures to help solve this? Since the other thread was for a 2007 the pin outs are different. I can test resistance etc. but do not have access to oscilloscope.
Is it possible to swap wires at solenoid pack and PCM/TCM to rule out wiring, say swapping 2-4 wires with OD wires? Seems that would be more definitive if possible.
Any help is appreciated.
