Hey guys, this might be a long shot, but I’m hoping someone here will have some suggestions.
I own a 2003 Dodge Ram 5.2L
When purchased it was running a bit rough, so I went over most of the standard items (spark plugs, cap & rotor etc) and afterwards it ran great. I took it on a 5000 mile trip with no problems, but as I got it home it was running rough and then would not start. Moving the cap & rotor will get it to fire up, but it’ll stall out almost immediately. If I adjust the cap & rotor I can keep it running, but only with the throttle slightly open. When it’s running, it sounds fine.
With lots of googling and trouble shooting I found that they can have a faulty intake plenum gasket. I verified there was oil in my intake, and replace the intake plenum with the Hughes Engine kit - It comes with an aluminum plate instead of the steel one, with all new gaskets etc. While I was in there, I changed the intake gaskets, thermostat, coolant bypass hose - any related items I could think of.
It seemed the engine sounds slightly different (better) but it will still stall with the same symptoms. I hooked up an OBD that shows live read-outs, and found that the timing is advanced to around +34, and when it stalls out, it stalls around +22. I’ve changed the cam and crank position sensor with no change. I’ve checked for vac leaks with some carb cleaner and haven’t found any.
The ADS relay was swapped with the AC Compressor relay to rule that out also.
It seems to me as though it’s timing related, although I’m not certain. The vehicle seems to change timing advance enough to kill itself but I can’t figure out what to check next. The final clue potentially is that no matter what the rad fan runs full blast. I’m not sure they’re related but it seems odd to me.
Items on the way are spark plugs (again), coolant temperature sensor, gas cap, idle air control valve, and throttle position sensor.
I’m wondering if anyone has had similar issues or could shed some light on the problem. Thanks in advance!
