Greetings,
I have a 2003 Dodge Stratus SE 2.7L with approximately 105,000 miles. It has always been an excellent vehicle! So the other day, I came out from work and to my dismay was greeted by a large puddle of antifreeze under the car. After a closer inspection I found that it was coming from the water pump weep holes, both of them, and then I knew exactly what the problem was. I had the car towed home to avoid any problems. So now I need to go about the business of having the internal water pump replaced. I don’t think there was any engine damage, as it sounds good with no ticking, and never overheated. I understand that kits are sold with all the parts including the pump, timing chain, timing chain guides, timing chain tensioners, cover gasket etc. So can anyone direct me to the best quality kit available…. (does MOPAR make one) I don’t want a cheep one made in China with plastic parts. lol. I’m not doing it myself, but plan to take it to the best engine mechanic I can find.
Also are there any additional parts that are recommended to be changed at the same time due to ease of access such as the oil pump or spark plugs (I heard the plugs had to be taken out to perform the procedure anyway). On that note, I do get an intermittent low oil pressure light occasionally (like once a month), but only at idle. As soon as any RPMs are added, it quickly goes out. I assume that it is just the sensor, but could the oil pump actually be weak as well. Also about how much $ am I looking at to get all this work done?
Thanks,
Mo
Thanks,
Mo
